Connecting video doorbell 2nd generation 2K to a router
  • 1 Reply
  • 808 Views
RNM59
Does the video doorbell 2nd generation 2K connect to a 5g router?
I am guessing you really mean 5 ghz wifi.   If you are instead talking about a mobile broadband router (connecting to 5g cellular instead of fiber, cable, or DSL), then please clarify.
The doorbell only can connect on the  2.4 ghz band.
But almost all 5 ghz routers are dual band - using both 2.4 ghz and 5 ghz bands - so it should work.  Check your router specs before purchase, just in case you have one of the extremely rare exceptions.
  • 1 Reply
  • 809 Views
