Chime 2 and Wired Arlo Doorbell AVD1001 Compatibility
  • 5 Replies
  • 3276 Views
arnie99
Will a Chime 2 work w/ the Wired Arlo Doorbell without having to use a base station?
It should.   The Chime 2 doesn't connect to a base, and the wired doorbell can connect either to your home wifi or a base.
https://kb.arlo.com/000062573/Arlo-Chime-2-FAQ
5 REPLIES 5
arnie99
Are you sure?  Arlo tech support said a base station is needed.
I misread your post, and assumed you meant the AVD1001 (wired video doorbell).
The audio doorbell (AAD1001) does need a base station.
arnie99
Let clarify what I have. I installed an Arlo Wired Video Doorbell - Black SKU: AVD1001B-100NAS connected via wifi to my router. It fails to work w/ my mechanical chime.  I want place the Arlo chime in a  location that allows me to hear when the doorbell is pushed.
Tech support might possibly have been confused on what you have.
The Chime 2 doesn't use a base, and it is compatible with the AVD1001.(Arlo Wired Video Doorbell).  https://kb.arlo.com/000062573/Arlo-Chime-2-FAQ
  • 5 Replies
  • 3277 Views
