Hi there,
My Arlo Video Doorbell seems to be working fine for several days now but I'm still not able to set the voicemail prompt message to another language than English. My visitors speaks French...
I know that you can change the "quick reply messages" to French but this doesn't change the "voicemail prompt" message. Is it a bug or a missing feature? Thanks for your support!
BTW: I checked this forum but didn't find a clear and useful answer to my question:
marcdevinci,
The voicemail prompt message is determined by the language used on your Arlo mobile app/mobile device when your account was created. This isn't adjustable after account creation.
The development team is working on a solution to allow this to be changed in a future update.
marcdevinci,
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
