Can't answer phone when doorbell is pressed
  • 8 Replies
  • 2416 Views
Chint
When someone rings the bell, the incoming call is notified on the phone, rings on my watch but I am unable to answer the call on the phone.
If I click the answer button on my watch, nothing happens on the phone.
If I click on the notification on the phone, nothing happens.
The call only stops when I press the hang-up button on the phone multiple times (at least 3 times. sometimes way more)
I have tried uninstalling the app and installing it back but got no luck.
8 REPLIES 8
ShayneS
Hi @Chint I have a few questions.
Which version of the app are you using? the latest is v4.5
Which phone/watch model are you using?
Chint
Hello we used latest version Arlo 4.5 and using iPhone 13 and 14pro,both device has a problem.tnx
ShayneS
Which iOS version are these phones using?
Chint
Hi it’s 16.5 latest version.tnx
ShayneS
Okay, to make sure I am understanding correctly, if you go out and press your doorbell right now, it will ring your phones, but you physically can not slide the answer call button?
Chint
Hi,it will ring my phones,and physically slide the answer call button as well,but when I answer call doesn’t see video and audio.tnx
ShayneS
Are you a granted access user? Does the screen load but it is grey?
Chint
Yes screen is grey,no video no audio.
  • 8 Replies
  • 2417 Views
