When someone rings the bell, the incoming call is notified on the phone, rings on my watch but I am unable to answer the call on the phone.
If I click the answer button on my watch, nothing happens on the phone.
If I click on the notification on the phone, nothing happens.
The call only stops when I press the hang-up button on the phone multiple times (at least 3 times. sometimes way more)
I have tried uninstalling the app and installing it back but got no luck.
Hi @Chint I have a few questions.
Which version of the app are you using? the latest is v4.5
Which phone/watch model are you using?
Hello we used latest version Arlo 4.5 and using iPhone 13 and 14pro,both device has a problem.tnx
Which iOS version are these phones using?
Hi it’s 16.5 latest version.tnx
Okay, to make sure I am understanding correctly, if you go out and press your doorbell right now, it will ring your phones, but you physically can not slide the answer call button?
Hi,it will ring my phones,and physically slide the answer call button as well,but when I answer call doesn’t see video and audio.tnx
Are you a granted access user? Does the screen load but it is grey?
Yes screen is grey,no video no audio.
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
