Can’t Disable leave a message without a sub (option greyed out) without a sub
  • 8 Replies
  • 3538 Views
JXDXW
Upon frim ware update I can not turn off "leave a message" the toggle is present in the app under the device "call settings" but not lit to be active as an option.
8 REPLIES 8
ShayneS
Can you provide a screenshot of this setting so I can see as well.
SimonSJ
I have exactly the same issue. Here is my screenshot.
ShayneS
This feature is unavailable without an Arlo Secure subscription. The feature requires recording/cloud capabilities which the basic plan does not provide at the moment.
SimonSJ
That's fine, as it's not a feature that I want, but how do I disable it when the option to do so isn't available? At the moment the doorbell prompts to leave a message.
ShayneS
 I understand the issue now. This should not be  announcing to leave a message if you do not have a subscription. I have provided this info to the development team and I will update you as soon as possible.
thanks for the info!
ShayneS
ShayneS
Are you still experiencing this issue?
SimonSJ
I now have an Arlo Secure subscription, so I have been able to disable the function.
  • 8 Replies
  • 3539 Views
