Upon frim ware update I can not turn off "leave a message" the toggle is present in the app under the device "call settings" but not lit to be active as an option.
Can you provide a screenshot of this setting so I can see as well.
I have exactly the same issue. Here is my screenshot.
This feature is unavailable without an Arlo Secure subscription. The feature requires recording/cloud capabilities which the basic plan does not provide at the moment.
That's fine, as it's not a feature that I want, but how do I disable it when the option to do so isn't available? At the moment the doorbell prompts to leave a message.
I understand the issue now. This should not be announcing to leave a message if you do not have a subscription. I have provided this info to the development team and I will update you as soon as possible.
thanks for the info!
Are you still experiencing this issue?
I now have an Arlo Secure subscription, so I have been able to disable the function.
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
