New to Arlo and just installed their wireless video doorbell. I get push notifications for motion and when someone presses the doorbell. I can swipe away the motion push notification, but not the door press notification. I chatted with Arlo who could only suggest uninstall/reinstall the app. This didn't work. I have a Galaxy phone. Curious if anyone knows a fix?
This issue should be resolved by updating to the latest version of the Arlo mobile app available from the app store. Please make sure you have the latest version installed and let us know if you continue experiencing the same issue.
+1. Same behavior for me on Samsung Galaxy Fold2, Android 11. Only way I have found to clear the notification in the shade is to reboot the phone.
I'd like this fixed by Arlo as it is kinda annoying if you answer the door in person as opposed to through the camera.
The development team is currently investigating reports of this issue. I will provide an update once I have more information.
Same issue. Pixel 4a/Android 11.
#1 Fri Sep 18 09:49:34 UTC 2020)
Clear all doesn't dismiss. Force stopping the app does.
I have noticed, also, that the phone is no longer being "Called" when the doorbell is pressed. However, our Google Home Mini speakers notify us that someone is at the doorbell.
Same issue here - Pixel 4a running Android 11 with 2/5/2021 security patch. Worked with support to create case #42295221 and included video of the issue.
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
