Arlo wired video doorbell error occurred "something went wrong so your doorbell cannot be registered
We changed our wifi password a few months ago and stopped using the doorbell. Trying to connect it too wifi and use it again and get this message at the end of setup "something went wrong so your doorbell cannot be registered to your account. Please try again
Remove it from Settings, My Devices. Hold the little sync button on the back for >15 seconds until the ring flashes white. Try setting it up again.
I tried this 5 times yesterday and same error message every time in the app, "something went wrong so your doorbell cannot be registered to your account. Please try again"
Are you using the same account now that you were using before?
This all started bc i changed our wifi password and waited a month or so to re set up the doorbell with new wifi password.
This might be hard to test, but it might be useful to try changing the wifi password back, and see if that works.
I can't remember the old password. Ill try adding it a few more times. If it doesn't work then I give up. Arlo doesn't offer support after 1 year or if your not subscribed. Arlo If you reading please unlock my doorbell so I can add it. Thanks for you help.
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
