Moved into a new house. Installed the doorbell (and cameras). The doorbell connects, but says it needs to update the firmware. After hitting yes to update - about 1 minute later I get the message it appears the device is offline. It doesn't come back on.
I've reset the doorbell.
I've reset the base station.
I've changed wifi routers - both 5g and 2.4g - same issue.
At my wits end.
What happens if you just connect it to WiFi instead of the base/hub? If that works, you can then move it to your base.
Justicecapt,
Are you still experiencing this same issue today?
Yes. The doorbell connects, but when updating the firmware I get a message the devices appears too be offline.
Same issue - falls offline when updating the firmware.
I have switched to a Google doorbell. It works perfectly. Goodbye Arlo.
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
