After i change my wifi password , i try to re connect my apps , choose network then i follow all the instructions i complet also but found an problem ...
- i can view live.
- the bell not get sound.
- there is no record , the trial periods ends after 2 months.
Then i restart then again i try all the above method bu not working ..
Waiting for solution
- i can view live.
Dhumbay,
Please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
Dhumbay,
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
