The setup flow for the video doorbell on the other hand directly jumps to connect to 2.4ghz WiFi….
I want to connect the doorbell to the smart base, but the setup flow never shows me the option to select it 🤔 What to do?
It sounds like you purchased the AVD2001 (wireless) doorbell. The older AVD1001 (wired) doorbell can be paired with the smarthub. But the AVD2001 doesn't support pairing with a smarthub yet - Arlo says they are working on that feature, but haven't said when it will be rolled out.
Best answers
I want to connect the doorbell to the smart base, but the setup flow never shows me the option to select itIt sounds like you purchased the AVD2001 (wireless) doorbell. The older AVD1001 (wired) doorbell can be paired with the smarthub. But the AVD2001 doesn't support pairing with a smarthub yet - Arlo says they are working on that feature, but haven't said when it will be rolled out.
Strange that a newer version is less compatible 🤦🏼♂️
@My Balance Now wrote:
I bought this package. 2 pro3 cameras, a smarthub and a doorbell. The camera setup offers to connect to the smarthub, all good.
My doorbell is connected through WiFi and I can browse the videos in local storage from the app. Are you trying to do something different than that?
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
