Tanyahiers502,
Support for syncing the doorbell with your Base Station is not quite ready. Firmware updates need to take place before you're able to onboard using a Base Station. This firmware should be available soon.
For now, you should be able to sync your Arlo Video Doorbell directly to your access point. If you're still experiencing an issue, take a look at this article for some troubleshooting tips: My Arlo Video Doorbell wasn't found during setup; what do I do?
Set up is failing in final steps.
I just purchased an Arlo Video Doorbell. I have 5 Arlo cameras and a base station. I have followed the instructions but can not get the doorbell connected. If I follow the app, it finds a base station, checks for firmware updates, and then can never find the doorbell. If I use the manual method, the doorbell flashes white, fails to acknowledge the QR code (no sound). I have restarted the router, confirmed i am connected on same 2.4 network, reset the Base, reset the doorbell and attempted both methods end to end over 8 times. I'm afraid something is Dead on Arrival and I'm spinning my wheels. I would prefer to use the hub, but can wait a bit for that as long as I can confirm the doorbell works at least on the local Wifi.
BASE=VMB4000r3
FIRMWARE=1.15.0.1_3162_d878851.
I may end up doing the same. I do hope there is a firmware upgrade that will resolve this. If not, and if the Arlo Doorbell will not integrate into my existing Arlo cameras, I would look again at the other brands. (If it has to be stand-alone why stay with Arlo.) Since I'd prefer it be Arlo, I'll give it another week (until 4/10), then start the return process if it's still DOA.
Eric, check your doorbell. The update must have come out and my automatically was showing on my arlo app I did not do anything. It looks great. Weird, but I will take it!
Yep! Same here.
Cheers
Yesterday FIRMWARE=1.15.0.1_3162_d878851
Current FIRMWARE=1.16.1.1_3348_facf74c
This might be part of the solution pushed to us.
Arlo Base Station- VMB4000 and VMB4500 are now compatible with the Arlo Video Doorbell. Please ensure that your base-station firmware is updated to the latest version, as listed below:
VMB4000 1.16.1.1_3348_facf74c
VMB4500 1.16.1.1_3260_facf74c
We're still in the process of releasing firmware to support Arlo Video Doorbell on VMB4540 and VMB5000 SmartHubs, stay tuned for an announcement on firmware availability if you have one of those SmartHubs.
Thanks!
Thank you James
Indeed it do see the doorbell in the hub now. However I do not see the ability to record or save any events. Neither to the hub or cloud. I should have this ability for at least a 30 day period should I not? Perhaps there are additional steps I need to execute. Please advise.
-Eric
EricShaver,
For content to save to the cloud, you must have an Arlo Smart subscription. Check Settings > Subscription to be sure your doorbell has participating in your existing subscription plan if you have one already.
Eric, you should have the complimentary subscription if you are in the library it should say select in the top right corner. Once you select there should be options for downloading. Mine says I have 3 months free.
Bbumps62,
VMB3500 is not compatible. For more information on this, take a look here: How do I connect my Arlo Video Doorbell to an Arlo SmartHub or base station?
I just bought the ultra 4 pack from Costco. Hooked it up not issues to my orbi system. Tried to install the video door bell and it can not connect. I think it’s a 2.4ghz problem but I’m not sure. I’m about to rip it off the wall and chuck it down the street. Any help?
You unplug the hub and try to connect the doorbell directly to WiFi?
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
