Arlo doorbell won't ring when pressed.
  • 1 Reply
  • 1017 Views
Jorge77
All of a sudden, my doorbell won't ring when pressed. Everything else works and on my app it says traditional chime is off. I can't change it when I press on it. Anyone else had this problem?
Try toggling power for the doorbell (turn circuitbreaker off/on with a brief pause or remove one wire from the back of the doorbell for a short time and then reinstall it).  You may need to remove the doorbell from your account and additionally hold the reset button on the back of the doorbell for >15 seconds until the ring starts flashing. Use the Add New Device selection on the Devices card to see if that helps.
  • 1 Reply
  • 1018 Views
