- 2
briansl1976,
The development team is currently investigating reports of this issue. I will provide an update when I have more information to share.
I know, briansl1976, my post is to help okdave connect to his router in the meantime. I also cannot connect to the SmartHub.
Just purchased the Video Doorbell. Cant connect to base station. Rebooted base station several times- reset the doorbell several times. Doorbell NOT found. Yes was able to connect using the wifi method but not what I want.. All firmware up to date and doorbell update its firmware when I connect it to wifi.
I had the doorbell connected to an older base VMB4000 and it works fine. I wanted to use the new base so I didn’t have to pay the smart feature fees and use local storage. For having cool tech sure has terrible customer service, follow up, and innovation on product.
Hi, No, no response. I have had one request to update my case number. I did so with several updates where I also pleaded to get a proper answer and that they communicate with the customers. Then everything went dead again. No sign of live og contact! I do not believe that I am there only one with no response or lack of answer from Arlo. There must be many other there!! I will keep up my requests for communication/answer. So, we can hope that will respond to this responsibilities. Brgds Roy
Any updates on this issue yet ?
First Arlo video doorbell I bought had to be removed after installation when it turned out that the primary winding of the transformer was open and the doorbell didn't get powered. Reinstalled the old doorbell while waiting for the replacement doorbell to arrive.
Today I installed the replacement doorbell and this one will not connect to the 4540 base station even though it detects the base station and confirms that it is up to date. (The four Pro 3 cameras work w/o issues.) Next tried to set it up w/o base station but it doesn't ring when attempting to get it to read the QR code (tried different distances, angles, brightness etc. on the phone).
I am afraid, I have to reinstall the old doorbell once more. It is sad, having devices from a single manufacturer that are not compatible. You would expect Arlo to test their gear before putting it on the market.
@superman2215 Connected to the smarthub and connecting via 2.4 WiFi are two different things. Connecting to the smarthub is the issue that everyone is having. That has nothing to do with your Orbi. But until that issue is fixed you should be able to connect the Doorbell over WiFi. I have an Orbi and it works. The tricky thing with an Orbi Mesh is that it broadcasts in both 2.4 and 5ghz. You can try connecting it to the Guest network. I found that worked. I also was able to connect it easily using a plug in transformer and moving far away from the Orbi. The signal is a little weaker so it should be the 2.4. Hope that helps.
Just wondering if I should ask Amazon for my $$$ back. I have had the device for a month and it’s just a fancy doorbell that rings.
Here to help, but a month is long time in today’s world for a fix.
@superman2215 I misunderstood your post. When you mentioned the 2.4 signal I thought you were trying to connect to WiFi.
Are you sure the issue is the Smart Hub not broadcasting the 2.4 signal? I would think if the Doorbell is connecting to the Smart Hub it shouldn't matter how the Smart Hub is connected to the internet. When going through the set up steps for connecting to the Smart Hub there is no mention of needing a 2.4ghz signal. Also, I'm having trouble connecting the Doorbell to my Smart Hub and my Smart Hub is connected directly to my Verizon Fios router via ethernet cable. So the problem is not limited to just Orbi or other mesh systems.
Thanks all for this thread. I just purchased the 4 pack pro3 cameras with the 4540 base. Also purchased the wired doorbell. I wasted all afternoon trying to get the darn thing to talk to the 4540. Was able to connect to my home wifi no prob. Hub4540 was a total waste of time as I just figured out by reading this thread. Tomorrow, I will return the doorbell to bestbuy and put my Ring doorbell back up. So many companies like this one will offshore their support (which is why you all are waiting) as well as their sw dev teams. I worked in big high tech for 38 years and I watched my company lay off many engineers in favor of the the cheaper overseas labor. Quality and customer service degraded FASTER than fast. I smell the same situation here with Arlo. Time to return the device and maybe consider it down the road once offshore gets their sh*t together. Again, thanks to you all cuz I won't waste anymore time with this doorbell.
Hi RH, no updates or comments received.
I have tried to solve this issue in more than 2 months time.
I have also replaced the video door bell unit. No success, no connection to base station or wi-fi.
I have a couple of other ongoing issues related to camera and no registrations to the SD card in base station.
But this is a discussion in another tread.
Will give Arlo one last chance to reply/fix the well known issue before I follow you in handing in
all Arlo units. Cannot have a system not working over several months, and no prospect of any solution.
This issue has been resolved with the latest release of the Arlo iOS mobile app. Please download the latest version from the app store.
- 2
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
