Arlo Wired Video Doorbell
  • 867 Views
Mjhendrix2012
Doorbell will not scan QR code. I have reset it and have tried all options. Is there way to install without QR
Is it chiming when you try?
Mjhendrix2012
No it’s not chiming at all. Just keeps flashing white
Ok.  Then the scan itself is failing.
It helps to move the phone around - slowly changing the distance to camera, and shifting the angle between the camera and the phone.
You can also try entering the WiFi network name and password here:  https://qifi.org/  Then print the QR code, and use the (larger) printout instead of the phone screen.
  • 868 Views
