I have the exact same issue!
Arlo support are absolutely useless and don't want to know about the problem! They just close my tickets and hang up the phone when I call them.
If you're having an issue with your existing chime not ringing on doorbell presses, take a look at the troubleshooting steps here: Why isn’t my existing chime ringing when someone presses the button on my Arlo Audio Doorbell?
I had the same issue and at first couldn't get the Arlo Video Doorbell to work. Replaced the transformer and the old chime. Finally get Arlo to display the flashing white and Amber lights. After 20 minutes, the doorbell is operating and paired into my Arlo hub with other cameras. I installed a new Chime, brushed nickel model with 10 tunes from Lowes. At first, chime wouldn't operate. Checked wiring from the transformer to the chime and to the Arlo video doorbell. I finally reset a button on the Chime for 10 seconds and it worked. Would only play the first 8 notes from the tune selected. Instructions on the Chime required a small diode to be wired on the Arlo across the two contact screws. After installing, the chime tunes played without a problem - again and again. They would play when the Arlo Video doorbell would light up the white light as someone approached the built in camera. I disconnected the diode and the doorbell works and the chime play partially but still works fine. Not sure of any other Chime that might work better. I'm happy with the Arlo Video doorbell and knowing who is at the front door. Also like the speaker through the smartphone app.
Just installed the video doorbell to replace a recently purchased Nest Hello that I wasn't happy with. Everything is good, but the mechanical chime will not ring from the Arlo, although it worked fine with the Nest. When I remove the cover of the chime I can see the plunger moving slightly, but not enough to strike the chime. I checked the wiring, checked that the switch is set to "o" and checked voltage at the chime (18 volts). On hold waiting for support for more than 30 minutes now.
In the end, I found a chime box and transform designed for 16v (it's on Amazon UK - search for nest chime box 16v), and finally my Arlo is happy.
It's cost me another £45 to get to the point of having a working Arlo, and support have been useless, but now it's working (and with a significantly redesigned mount) it works ok.
Not great, just ok! Would I recommend it? Probably not
I spent quite a bit of time on the phone with a very patient and helpful Arlo rep. Finally figured out that my old transformer (1978 or 79) is only 5VA, which isn't nearly enough to power the Arlo and ring the mechanical chime. I'll try installing a new transformer and I assume that will solve the problem.
The problem was the original (1978 or 1979) transformer that it turned out was only 5VA. Picked up a 30 VA transformer at Home Depot today and now the mechanical chime is working fine with the Arlo doorbell.
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
