In the past week, my video doorbell said that it had lost connection. I have a Eero mesh network. When I factory reset the doorbell, the Arlo app can’t find the doorbell, although the Eero app says it is connected. The Arlo support has not been able to provide any help and I’m way ahead of them. Seems like folks have ran into this before and fixed the issue by connecting the doorbell riptide the Eero guest network. However, I do not want to use the guest network. I’m thinking about just throwing this thing in the trash and not recommending it to anyone.
Which version of the Arlo mobile app are you using when trying to onboard your doorbell? Can you make sure you have the latest version of the Arlo mobile app 3.5.4 installed.
When you reset the doorbell, did you also remove it from Settings, My Devices?
There have been various issues with Arlo and Eero mesh networks. I don't have that router so can't comment on fixes so hopefully someone with an Eero will jump in. You may also want to use the Contact Support link at the bottom here since they may have specific suggestions relative to Eero.
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
