Arlo Video Doorbell worked for about 15min
I have tried two arlo video doorbells and both worked for about 20min and then disconnected and have no lights. I confirmed before install I was gett 20 volts everything was correct. I have taken both off and reset them both checked my connections even hooked up the old doorbell it works but no lights on the video doorbell.
agenisio,
The symptoms you describe here sound like an issue with the transformer, take a look here for more information:
The LED on my doorbell is off; what do I do?
How do I install the Power Kit for my Arlo Video Doorbell?
How do I measure the voltage of my doorbell transformer?
If you're still experiencing an issue, I encourage you to open a support case or reach out to a professional electrician to further investigate the issue:
Where can I find professional help to install my Arlo Video Doorbell?
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
