I purchased an Arlo video doorbell to compliment my five Arlo cameras and lights. The doorbell app. calls for connection to 2.4 gHz internet service (not Smart Hub). I cannot determine how to configure my mobile device iPhone to that service setting. Likely a user (me) error issue, but perhaps someone who experienced such could help. Thanks.
You can connect the doorbell to either your WiFi or to your base - either works fine although if you don't plan on purchasing a subscription after the 3 month trial runs out the base can be configured with a USB drive to record locally. Your choice.
As to the problem, make sure your phone is on your WiFi. Connecting to the 2.4GHz band SSID may be useful. The app simply tries to tell the camera what the network name and password is so it can connect.
Personally, I prefer the connection to the base as long as there's no connection problems such as weak signal.
Ktest,
Take a look at the steps here if you're trying to connect your Arlo Video Doorbell directly to your router: How do I connect my Arlo Video Doorbell directly to my WiFi router?
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
