  • 2 Replies
  • 4048 Views
NewUserTX
I just purchased and installed a new Arlo Video Doorbell. When I turned the power back on my doorbell chimes would not stop ringing. I had installed the power kit according to instructions. I then removed the power kit and the chimes still rang continuously. I see that there may be no solution for this. Before installing ARlo, I had a doorbell switch that was continuously lit. I would think that was a good sign which meant that the wired doorbell would also continuously get power. This has turned into a nightmare situation. How can something so high tech be done in by something so low tech? Is there really no solution to the continuously ringing doorbell?
Some chime systems are incompatibile, and it is possible you have one.  You should also check to see if your doorbell transformer is within spec.
Unfortunately Arlo does not have a public list of compatible (or incompatible) chimes.  However, Ring does - and if a chime is incompatible with Ring, it is almost certainly incompatible with Arlo.  Their list is here: https://support.ring.com/hc/en-us/articles/209028546-Ring-Video-Doorbell-Pro-Chime-Kit-Compatibility...
The NuTone models Ring says are incompatible include the following:
  • IM-3303
  • IM-4406
  • IM-5006
  • IMA-516
  • L-53 Sonata
  • LA-174
  • LA174WH
  • LA-55
  • LA-52 Harmony Musical Chime
  • LA-52A
  • LA-52N
  • LA-52NA
  • LAC-55
  • LBC-55
  • LA55
  • LAC55
  • LD-49
NewUserTX
Thank you for the reply. It now unfortunately appears that I have a useless Arlo video doorbell. I can not return it to the store because then mounting frame was damaged as we removed it. I do wish that Arlo had made the lack of compatibility more public. I am now running into more and more people who had the same issues. I will research the transformer before totally giving up.
  • 2 Replies
  • 4049 Views
