- Email to a Friend
G'day all,
I am looking at buying the new Arlo Video Doorbell. I can't find much information about it. The Arlo website is kind of useless.
I have the Arlo Pro 2 base station (VMB4000 I believe). Does it connect through this hub? Are there any online manufacturer installation instructions that I can view before I purchase the product?
Cheers in advance
J
- Email to a Friend
@Kwenda wrote:Then can the Video Doorbell trigger my existing Arlo Chime.?
No, At present you can't use the Arlo chime with the doorbell.
@Kwenda wrote:Can I just supply the Arlo Video Doorbell with the correct electrical power. Using the small electronic device supplied in the box if necessary.?
Yes. The transformer spec is 16-24 volts AC and 10 VA. Any power adapter that delivers that will work. You can insert the power module across the transformer (putting the switch in the correct position).
- Email to a Friend
- Email to a Friend
- Email to a Friend
@Droi wrote:
Hi, hooking up the video door bell. When done Can’t find device and won’t activate the old doorbells? Help. We have 5 cameras and 1 video doorbell. Had all hooked up.
You could contact support: https://www.arlo.com/en-us/support/contact.aspx
Is the doorbell getting power? Is the transformer within the spec?
Some folks have had issues with the QR code method of syncing to their WiFi. I just entered the SSID/passphrase myself.
Also if you have spaces or other unusual characters in the SSID, you might need to change it.
- Email to a Friend
- Email to a Friend
2. If no cloud storage with without subscription, does video doorbell connects to base station for local storage? (Yes/no)
3. If it doesn’t connect to base station, does it directly connects to internet over wifi? (Yes/no)
I think if they don’t answers these questions, I will buy is from store and use it to verify above questions. If I found “no” to first 2 questions, I will return it back to store. Once they will figure out many people returning doorbell they will automatically learn from their mistakes. I have no reason to choose Arlo video doorbell over Ring doorbell unless there are any value adds to stay in the ecosystem.
- Email to a Friend
Answers, in order of your questions
No
No
Yes (connects over WiFi to your Arlo online paid subscription)
If you want local storage and free 7 days of storage, this is NOT the camera for you
- Email to a Friend
It was in my case. Camera is mounted on perpendicular sidewall, only a few inches away from the plane of the front doors. I used the angled mount.
View of front porch
Arlo Video Doorbell
