Arlo_VMB Default password
  • 1 Reply
  • 11337 Views
AmickAndAmick
My Arlo doorbell want me to sign into the Arlo network... I think. As seen in screen shot below, the password says unchanged. Google says the default is 12345678 but that doesn't work.
Can some one help me?
My apologies if this has been ask a million times... i tried to search but couldn't find the answer
You can't log into the Arlo hubs and bases - it's just not possible. To connect your doorbell to your hub or base, you just follow the app's directions, choose the hub/base you want to connect to and the discovery is automatic from that point. If choosing to connect to your own WiFi, you choose the SSID that your router provides and the password you set for it.
  • 1 Reply
  • 11338 Views
