@Sekhalaf wrote:
Is there something with the high frequency communications btw doorbell and chimes?? Anyone else?
Not sure where the "high frequency communications" idea comes from, but I've never heard it from Arlo. AFAIK, the power module simply diverts power that would normally go through the chimes, in order to prevent the chimes from ringing or vibrating when the doorbell isn't being pressed. I believe it does sense current flow through the circuit, but that doesn't require any special communications.
Is the doorbell chime setting set to "digital"?
Assuming yes, then one option is to simply replace the transformer - especially if it is old. My own system was misbehaving (the power module wasn't working correctly) until I swapped it out - even though it was within the specs.
Could be that upon first setup I only had the digital “chime” set for 4 seconds so it would start and then abruptly end with a weird “thump” sound because it was not completing the full melody. Maybe it was that sound. I fixed that. Not making that weird sound. So maybe dog needs to readjust to absence of that disturbing brief sound. It was a bit of disturbing sound if you’ve heard it.
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
