Arlo HD wired doorbell Too long a delay from doorbell pressed to phone ring, to video on phone
  • 5 Replies
  • 1411 Views
Doumat
I have an Arlo HD wired doorbell.  When someone presses the button, it takes about 5 -7 seconds for the phone to ring, and then when I answer the phone about another 5 seconds before the video shows up on the phone.  I know I have a strong wifi signal small townhouse with mesh network.  Any ideas anyone?
Thanks Doug
5 REPLIES 5
ShayneS
There is a normal delay with IP based cameras. Does the same issue occur over wifi/mobile data or another device?
Doumat
The same on both wifi and on mobile data for the phone.    Wifi is gigabit internet with a mesh network and strong signal both to doorbell and phone.
ShayneS
Is there any concrete, multiple walls between the doorbell and the router or Hub? having the router/hub next to another wireless frequency device might affect performance as well.
I tested this and I'm not able to replicate the issue as described.
Doumat
Thanks I will try moving one of my Mesh network notes closer and give it a go.
ShayneS
Sounds good, let me know how it goes. it does sound like there may be an interference issue or possibly bandwidth interruption somehow.
  • 5 Replies
  • 1412 Views
