Arlo Essential Video Doorbell AVD1001AR1.2
iOS for iphone 16.1.1
For the last month or so, I've been getting hundreds of motion detector alerts a day when nothing is there to set it off. I've tried using the Motion Detector Test to reduce sensitivity from 80 down to 29 and it hasn't made a difference. Even worse, sometimes after a few days, the app will set itself back to 80 or so for the sensitivity.
How do I fix this?
What solved the problem was shutting down the circuit breaker providing power to the device. And then turning it on again.
Note: It had worked fine for at least a year or two before this...
You need to change the setting in your modes and rules, not the test which is just, a test.
Don't forget that the sun's IR effect changes as the sun's angle changes.
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
