Added Doorbell camera to Arlo Pro 2 but 7 day free recording is not available?
I have owned a two camera Arlo Pro 2 system and added the doorbell.
Our free 3 month subscription to the Premium package on the doorbell ran out and now I get no recordings on it.
I still get the 7 day free recordings on the other cameras and was under the impression I was just adding one more camera to the package. Is it required that I sign on to a subscription for the doorbell? If so, that is very disappointing as I originally purchased the system based on no subscription requirement and convinced a friend to also purchase Arlo because of it. He purchased and installed the doorbell and is now under the 90 day free Premium deal. He will not be happy when he learns he needs the subscription package.
This was never made clear to me when I purchased the doorbell and neither did my friend.
Is there any way I can get my hub to record all cameras no matter what generation, or am I stuck with a subscription for the doorbell?
hiosilva,
To continue experiencing the same benefits offered during your trial period, you will need an Arlo Secure subscription plan for your doorbell. For more information, take a look here: What options will I have when my Arlo trial ends?
This doesn't really answer my question.
I knew that the Premium trial was coming to an end but thought that I could get 7 day recording on the hub that has my 2 Arlo Pro 2 cameras already installed.
Is recording with the Arlo Doorbell only available with a subscription?
Yes.
All the newer cameras (starting with the Ultra in 2018) need a subscription for cloud storage. That includes the doorbells.
I am guessing only certain base stations do this. Which ones?
I have older cameras and base station hardware VMB3010r2
Can I record to this base station (without a subscription)?
The answer is here: https://kb.arlo.com/000062284/What-is-the-difference-between-each-Arlo-SmartHub-and-base-station
https://kb.arlo.com/000062393/My-Arlo-camera-is-connected-directly-to-my-WiFi-router-how-do-I-connec...
it is not compatible.
This article applies to:
VMB4000 VMB4500 VMB4540 VMB5000 AVD1001 FB1001 VMC2030 VMC2020 VMC2032 VMC2040
So it seems to be compatible (and not compatible)unless there is some other “wire free”
The best base station VMB5000 is “Compatible with: Arlo Ultra, Ultra 2, Essential wire-free, Pro 4, Pro 3, Pro 3 Floodlight Camera, Pro 2, Pro, Wire-Free, Wired Video Doorbell, and Audio Doorbell” which seems to suggest the Essential wire free doorbell (model AVD 2001B) I have. Can anyone clarify?
@Bainf wrote:
The article says my base station is “ Compatible with: Arlo Pro 2, Pro, Wire-Free, and Audio Doorbell”. So I guess that means Essential video wire free doorbell.?
No, unfortunately it doesn't mean that. The original Arlo camera (before the Pro) was called the Wire-Free. There are folks still using that camera. I have pointed out the problem with the KB language to Arlo, so hopefull they will adjust the text to make it more clear. Wire-Free should always have "Camera" added after it, whenever an article refers to that original camera.
Arlo has said they will add the ability to add the Wire-Free doorbell to a base station. Hopefully they will release that capability soon - lots of people here are wanting it.
I have the essential wire free cameras which are specifically referred to in some hubs compatibility. So so am still confused.
The best hub says
“Compatible with: Arlo Ultra, Ultra 2, Essential wire-free, Pro 4, Pro 3, Pro 3 Floodlight Camera, Pro 2, Pro, Wire-Free, Wired Video Doorbell, and Audio Doorbell” which suggest the (essential) wire free ones that I have.
If that is the case, then the wording suggests the wireless doorbell is not compatible with any hub or base station ? (Or compatible with all!)
That is in fact the situation at the moment (as I tried to say above).
It's a feature Arlo says they are working on, but not released yet.
Thanks for response. Much appreciated
I am now 100% happy with answer and 0% happy with Arlo and their wording. I have actually wired my wireless doorbell which makes it more annoying.
I would have kept my $2 doorbell if I had known.
The good news is that Arlo (finally) released new firmware for the AVD2001 a couple days ago that will allow it to be paired with compatible bases (VMB4000, VMB4500, VMB4540 and VMB5000). Make sure the doorbell is running 1.2.0.0_621_903a525_c998ba4 or later firmware before you switch it to the base.
Homekit integration isn't available yet, they are saying it will be available "early next year".
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
