I have two Arlo video doorbell‘s wired they were both working at one time then stopped so I changed out the transformer to a 24V and 30 VA. Now one doorbell works but the other doorbell I can’t even get to light up. I’ve tried resetting it numerous times. I’ve also tried to contact Arlo and I keep getting a message that they will get back to me in 1 to 2 business days well it’s been over two weeks so much for that! It was better when they had a 800 number you could call. Very frustrating! Does anyone have any suggestions for me to try?
Are you using the support options in the app? If you have a subscription, there should be a phone option.
Just to double-check - are you using the reset procedure here: https://kb.arlo.com/000062438/How-do-I-factory-reset-my-Arlo-wire-free-camera
Also, have you measured the voltage at the second doorbell?
I do have a subscription but can’t find a phone number.
Did you go into the "support" section of the app, and select one of the doorbells?
You should see a phone icon, that will call Arlo support if you select it.
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
