AVD 1001 False Alams Arlo essental Wired Video Door Bell
  • 1 Reply
  • 555 Views
Retired_Member
Not applicable
@Retired_Member wrote:
when the outside Temp is in the teens and it see motion it says someone is tampering with door bell.
The voltage is correct.
Transformer is the 24v.-20VA.
Have you checked that the wires are tightly connected to the doorbell?  A glitch in power can cause this, and the connection might not be as tight at low temps.
  • 1 Reply
  • 556 Views
