@ Key holder cannot communicate with doorbell audio after answering a cal
Is the issue that the key holder can't hear the person at the door?
Or that the person at the door can't hear the key holder?
What is the phone model (and what OS version is it using)?
The person at the door can't hear the key holder
Hi Stephen B, yhanks for.your prompt response, I'm just waiting for a reply from the keyholder
One possibility is that the app doesn't have permission to access the phone microphone.
Another is that the microphone is too far to pick up the keyholder's voice - so the keyholder should probably try holding the phone up to their ear, to see if that makes any difference.
If the keyholder has a headset, then it might also be worth trying that, and see if that makes any difference.
Answer to second question 'Samsung A22 Android 12
Hi Stephen B, I've checked but I don't know how to check if the app has permission to access the phone microphone, please can you help
I've had an iPhone for a while - and haven't used Android 12.
Does this help?
