Hi,
I'm trying to pair my AVD2001 with a new account but the reset won’t work.
The battery is charged, and button lights are white in a breathing pattern.
Holding the pin in the reset hold for any lengthof time (15sec, 30sec, 60+seconds) does not start the reset process - i.e. I do not see rapidly blinking white lights.
Any ideas?
Can you feel the button "click" when you press it? If not, perhaps you're not actually pressing on it.
yes, there's a definite click.
Assuming the battery is charged, the fastest resolution would be to swap at the store.
