  • 1064 Views
putty99
Why is it that the Arlo wire-free door camera has dropped in performance and recordings of videos ever since I added the door camera to the SmartHub? When I go back to the door camera on wifi only, the performance is noticeably better. There are no glitches to the recording and when I press live view, it does not look badly pixelated the first view seconds of live viewing?
Anyone else with the same issue?
putty99,
The symptoms you're describing indicate a connectivity issue due to interference. This could be due to the location of the SmartHub. If possible, try relocating the SmartHub so that it is closer to the doorbell, and try to avoid placing it near other high powered sources of WiFi that could be causing interference.
putty99
Doesn’t the smart hub need to be connect via Ethernet? Or can it be connected to via Wi-Fi? I have the hub connected to my router which means it’s with 3 feet of the router. What would be the optimal distance if Ethernet is the only option? Or should I buy an Ethernet cable that is longer than the one the smart hub came with?
The smarthub has to be connected with Ethernet.  It'd be good to try moving the smarthub as far away from the router as the ethernet cable will reach (which would be 5-6 feet if you are using the cable Arlo provided).
  • 1065 Views
