Can I remove my regular doorbell and l install the Arlo Essential Wirelss doorbell camera where the traditional doorbell was? Will the screws matchup? Or do I need to use the mount that comes with the camera?
Thank you.
The screw holes are very likely not going to match. In any event, the mount is required to hold the actual doorbell.
Thank you.
