- English
- Doorbells
- Arlo Video Doorbell Wire-Free
- Re: How to place my Essential Wireless Doorbell on...
We have a garden on our front porch where our doorbell camera is located. When my wife goes out to tend to the garden, the doorbell sends 50 to 75 alerts while she is out there. My other Arlo cameras have a disable option in settings, but the doorbell camera does not. Is there any way to easily disable the camera while she is out there?
Thank you in advance for your advice.
Which user interface (UI) are you using - the old one with Library to view videos or the new one with Feed? You could switch modes which may disarm all cameras or, with the new UI, go to the mode in use and select the doorbell. Toggle the Motion Detection to off which will disarm the camera. WHen gardening is done, toggle it back on.
Guru: Sorry for taking so long to reply. Thank you for the advice; it worked well.
