Doorbell doesn't allow connection to 5ghz? Only 2.4ghz?
  • 1 Reply
  • 8392 Views
CameraAddict
Does the wirefree doorbell allow wifi 5ghz? Only allows 2.4ghz when I set it up.  Will you be pushing out a new firmware to allow 5ghz?
That would require additional hardware - a 5GHz radio - so it's not a firmware issue. I believe the reason for use of the 2.4GHz usage is for distance capabilities since 5GHz can't cover as much territory and is more easily blocked by walls, etc.
  • 1 Reply
  • 8393 Views
