Have you reset the doorbell?
https://kb.arlo.com/000062346/How-do-I-reset-my-Arlo-Essential-Video-Doorbell
@AB2015 wrote:
Just opened a brand new avd2001 doorbell and can't get it to connect to wi-fi or base.
You can't pair it with a base yet - Arlo says they are adding that feature, but haven't said when.
Of course you do need to be careful to type the SSID/Network name and passphrase correctly (both are case sensitive).
If you have unusual characters in either of those, you might try changing them.
@AB2015 wrote:
Should it connect to my wi-fi?
Yes.
Is there something unusual in your network name or passphrase?
I have the same exact issue. Both of mine stopped working last week and I cannot get either to connect to wifi even after checking w/Arlo support. It goes through and says its connected to wifi and then at the very end it says it is still disconnected. At a loss here.
Criswood,
Could you provide more details? What troubleshooting steps have you already taken? Where are you seeing it say it's disconnected?
I had the same issue and I found the solution!
