Can I make the wireless doorbell wired?
  • 4 Replies
  • 1710 Views
Triade
I have arlo doorbell wireless and i want to wire it (the batter goes down too fast.) i bought a doorbell trasformerà, i set all wires and doorbell and also the app, but when i go in the app i see the batter still go down. Someone can help me?
What are the specs for the  transformer? We need to know the voltage and power (VA, (volt-amps) A (amps) or W (watts) ratings. Also, use a voltmeter at the doorbell to verify the voltage is there and correct.
Triade
https://www.amazon.it/dp/B07J2NWYC4?psc=1&ref=ppx_yo2ov_dt_b_product_details
I set Neutral to the 0 and the live on 24V and the wires direct to the doorbell
That should work. You may want to try the 8V selections if you're currently using either of the higher voltages since the available current in the higher voltages may not be sufficient.
Triade
The only thing that confuse me is this
On the amazon transformer page is written:
This transformer suits only doorbells with max power 8VA
 in alro  documentation talks about a 10VA power.
  • 4 Replies
  • 1711 Views
