- English
- Doorbells
- Arlo Video Doorbell Wire-Free
- Re: arlo essential wireless doorbell - won't ring ...
i installed the wireless doorbell Ok and connected it to the 10.8 v bell wires to it . But then I erronerously chose NONe for the "Traditional Chimes " option, It should have been mechanical . But the menu locked up and I have no choices now. Can't cnange it. Chimes dont ring.
How can I change it ? The only solution on the forum was to reinstall the whole thing. Why ?
Any simpler fixes. TY
You can perform a factory reset by following the instructions here: How do I reset my Arlo Essential Video Doorbell?
You can also try and reboot the doorbell by removing it from the plate and release the battery.
