doorbell chime suddenly stopped working
My doorbell chime suddenly stopped working. The video and sound are fine. Any suggestions on how to fix it?
I suggest taking down the doorbell and briefly touch the wires together. If the chime sounds, then the issue is the doorbell. If it doesn't, then the issue is either the chime or the transformer.
Hi - I have a similar ongoing issue. The doorbell suddenly fails to detect motion, and does not trigger the chime when pressed. In the app I go to devices / settings / doorbell / restart .. and it works again .. for a while - but really not a solution, as it is happening daily - so without constantly checking I don't know whether it is functioning!
Nothing particularly untoward about my installation - except, perhaps, I have the USB cable permanently connected. I suppose I could unplug it to see is it has similar behavior under battery power - but I do quite like the "set and forget" option of being plugged in .. and it had been working continuously for about 6 months.
I'd be grateful for any suggestions TIA
Brian
blueduck,
Let us know if you still experience the behavior after removing the charging cable.
2nd Gen
Arlo 2nd Gen
Arlo Video Doorbell
audio
AVD3001
AVD4001
AVD4001-100AUS
communication
deta
Doorbell
drained battery
Feedback
homekit
intermittent
Mechanical chime
no app model
noise
Phonecall
reset
Secure Plus plan
Secure Trial Active
speaker
Talk
token
Video
wired
Wmb4540
