AVD3001 doorbell at full charge-- typical run time until needs charge
  • 1 Reply
  • 1301 Views
sgtyoung
AVD3001 doorbell
The time between charging is potentially highly variable. It depends on signal strength/quality as well as the amount of time spent recording, live viewing and answering the doorbell. "Normal" use should perhaps give you 2-3 months (+/-) between charges but could be much more or less depending on the above variables. Only testing/monitoring in your environment will give you an accurate answer.
