  • 11 Replies
  • 517 Views
Smurf1234
2nd generation doorbell
11 REPLIES 11
Do you mean you're trying to talk to the visitor, they can hear you but you can't hear them? Check the doorbell settings under Audio Settings to ensure the mic is enabled and volume turned up. You might also want to ensure the original plastic protective sheet, used for shipping, is removed.
ReiA84
Yes. Something happened around early Oct and it seems everyone with an AVD3001 doorbell camera can only hear white noise. I can talk to my guest fine but I can’t hear anything but white noise. Bad update must’ve got pushed to us.
ShayneS
@ReiA84
Does this occur over mobile data and Wi-Fi? What troubleshooting steps have you tried so far?
ReiA84
Both WiFi and mobile network. I have done a reset and even tried restarting my router multiple times. Also have a ticket open with Support.
ShayneS
Does this occur with other handheld devices as well if you login there?
ReiA84
Yes. I have two mobile devices and a tablet. All 3 are experiencing the white noise for a month now.
ShayneS
@ReiA84
Please reach out to the Support Team to further investigate this symptom you are experiencing. You can find several options for contacting support though the Arlo Mobile App by navigating to the Profile icon > Support Center > Select device > contact
ReiA84
I have. I had a ticket open which they closed after 7 days of no resolution and making me redo all the steps I did before even speaking to them.
ShayneS
@ReiA84 and you tried reinstalling the device?
ReiA84
Yes. Tried every troubleshooting tip they have listed and asked me to do when I opened the ticket.
ShayneS
I have escalated your case & someone from support will be reaching out to you as soon as possible.
