V2 live streaming not working
Recently 'upgraded' from a v1 which had been working perfectly for months in same location/network.
Set up no problems, firmware updated etc, but live streaming has never worked properly. Connects sometimes then a couple of minutes later doesn't. When it does work it takes ages to connect. V1 works perfectly on same network.
100/40 Nbn 3m from access point.
Alerts and viewing feed work fine
If you bring the doorbell closer to your hub or router, depending on how it's connected, does it work properly?
Read my post, 3m from access point...
V1 in same location works perfectly, and has done for 12 months
100/49 nbn
It's a troubleshooting step which is simple enough to try. Just because one device worked doesn't guarantee another will, especially if it's faulty.
2nd Gen
Arlo 2nd Gen
Arlo Video Doorbell
audio
AVD3001
AVD4001
AVD4001-100AUS
communication
deta
Doorbell
drained battery
Feedback
homekit
intermittent
Mechanical chime
no app model
noise
Phonecall
reset
Secure Plus plan
Secure Trial Active
speaker
Talk
token
Video
wired
Wmb4540
