- English
- Doorbells
- Arlo Video Doorbell 2nd Gen
- The device model is not available in Arlo Secure a...
While I try to add the device into the app, there's no "Video Doorbell 2nd Generation" in "Doorbells and Chimes", only the original version. Is there something wrong? Appreciate it!
Sincerely
Charles
2nd Gen
Arlo Video Doorbell
no app model
@charlescheng wrote:
Frankly speaking if that's the case, anything to do to pass the limitation?
The only thing I know that might work is to connect a VPN to the US, and then create an account. But you'd also need a payment method for the US. Note if you do this, you'd onboard the doorbell with the VPN turned off.
Where are you located? 2nd gen cameras/doorbells aren't supported in all regions yet.
Hong Kong.
Oh no, I didn't know this (region limitation) during purchase, I even dig a hole on the wall for the installation, then during the app setup I couldn't find out this model.
Frankly speaking if that's the case, anything to do to pass the limitation? My parents are both looking at me and the hole of the wall at odd now...
Appreciate any attempts to save me, thanks!
Sincerely
Charles
Finally, I'm managed to register an US account and everything worked perfectly! Thanks @StephenB !
Can you tell me how you did it? I have the same problem, I bought the second generation video doorbell and I have not been able to configure it because it does not show up in the application.
Read post 4
2nd Gen
Arlo 2nd Gen
Arlo Video Doorbell
audio
AVD3001
AVD4001
AVD4001-100AUS
communication
deta
Doorbell
drained battery
Feedback
homekit
intermittent
Mechanical chime
no app model
noise
Phonecall
reset
Secure Plus plan
Secure Trial Active
speaker
Talk
token
Video
wired
Wmb4540
