  • 6 Replies
  • 3073 Views
charlescheng
While I try to add the device into the app, there's no "Video Doorbell 2nd Generation" in "Doorbells and Chimes", only the original version. Is there something wrong? Appreciate it!
Sincerely
Charles
@charlescheng wrote:
Frankly speaking if that's the case, anything to do to pass the limitation?
The only thing I know that might work is to connect a VPN to the US, and then create an account.  But you'd also need a payment method for the US.  Note if you do this, you'd onboard the doorbell with the VPN turned off.
6 REPLIES 6
Where are you located?  2nd gen cameras/doorbells aren't supported in all regions yet.
charlescheng
Hong Kong.
Oh no, I didn't know this (region limitation) during purchase, I even dig a hole on the wall for the installation, then during the app setup I couldn't find out this model.
Frankly speaking if that's the case, anything to do to pass the limitation? My parents are both looking at me and the hole of the wall at odd now...
Appreciate any attempts to save me, thanks!
Sincerely
Charles
charlescheng
Finally, I'm managed to register an US account and everything worked perfectly! Thanks @StephenB !
Retired_Member
Not applicable
Can you tell me how you did it? I have the same problem, I bought the second generation video doorbell and I have not been able to configure it because it does not show up in the application.
Read post 4
