  • 1981 Views
steveandjackiec
Night vision is too dark due to a wall being too close on the left side of the camera. The wall itself is very bright causing the rest of the image to be extremely dark. Is there a way to get around this?
steveandjackiec
     I have attached a picture for reference. It is essentially the door jam which is very deep.
Edinburgh_lad1
I don't think so, but you could try selecting an activity zone. From experience, this could improve the situation, but only a wee bit. The other option is of course to move the camera, but by the sounds of it, it's unlikely.
Can you use the angle bracket to try to eliminate some of the wall from view?
SInce the wall is reflecting the doorbell's IR light for night vision, turning that off and using ambient light may be the best solution.
