Installation and screen output
  • 1 Reply
  • 562 Views
Ekersela
Hi, I just received the 2nd generation doorbell. It seems it can be connected to an external power source. Is it correct that it needs to be 8-24 volts AC? Any idea what device I can use??
On all the screen info on Internet, including the Arlo website, the images are squared. On my video I have a fish eye output. Handy commercial tricks?? Thanks for a usefull answer
Best answers
  • StephenB
    The doorbell is designed to handle the usual voltage to traditional doorbells - low voltage AC (8-24 volts).  If you have existing wiring at the door, then either look for the transformer, and check the rating - or check it the voltage with a meter.
    If you do not have existing wiring, then you can look for a compatible plug-in transformer.  There are several options (many don't specifically mention Arlo).  One is
    Note this is not a recommendation, just a pointer to one of several transformers.
