Just installed an Arlo Video Doorbell 2K (AVD4001) into a system with a mechanical chime and added it to our Arlo account (set to wired doorbell in the app). If the doorbell is plugged in, the old chime continues to ring non-stop until the Arlo doorbell is disconnected. We are not sure of the compatibility with the existing chime. It is also our understanding that this doorbell model does not require a power kit.
Can someone knowledgeable with Arlo doorbell installations look at the attached photo of the current chime and perhaps give a recommendation on a solution? If it is not compatible we could just use the doorbell on battery, but we much prefer to have it on power so we don't have to charge it.
Any help is appreciated!
Your chime uses direct current (12 v DC), and Arlo doorbells are only compatible with low voltage alternating current (8-24 v AC). So it is not compatible.
Thank you for the reply. We will just use it on battery then. I'm sure it will be fine, just more frequent recharges.
2nd Gen
Arlo 2nd Gen
Arlo Video Doorbell
audio
AVD3001
AVD4001
AVD4001-100AUS
communication
deta
Doorbell
drained battery
Feedback
homekit
intermittent
Mechanical chime
no app model
noise
Phonecall
reset
Secure Plus plan
Secure Trial Active
speaker
Talk
token
Video
wired
Wmb4540
