Doorbell 2nd does not install in Brazil
  • 1075 Views
MatheusFernande
I bought it in the United States and I'm in Brazil but I can't install it, the 2nd Gen model doesn't appear in the app.
It only shows up in the app if it is available in your country.
If you have a US payment method, you could create a US account by using a VPN that terminates in the US.
After that, you would disconnect the VPN, and add the camera to your account.  Don't enter the address for your location - it likely won't take one in Brazil, and a fake US address will lock you into the timezone of that address.  If the location has no address, you'll be able to set the timezone however you want.
Leonardo2024
How did you fix this problem?
Read post #2 above.
