- English
- Doorbells
- Arlo Video Doorbell 2nd Gen
- Arlo2nd gen doorbell and pro 2 cameras with free c...
Arlo2nd gen doorbell and pro 2 cameras with free cloud storage
Hello.
i have the pro 2 cameras with free cloud storage. I just bought the Arlo doorbell. I want to add to new device but it wants me to upgrade. If I upgrade will I lose my free cloud storage on the pro 2 cameras if I don’t like the doorbell? It’s my understanding that there is a 30 day trial on the doorbell. If it doesn’t work the way I want then I was going to return the doorbell.
thank you for your help.
A suggestion is to review the posts here on the forum about arlo user’s experiences using the newer app upgrade. It is important to note that once you upgrade the app your stuck. I.e. no way to back out.
Once you upgrade and install the doorbell, you do not loose the 7days free cloud storage on the pro2 cameras initially, if the doorbell subscription expires then you will need to uninstall the doorbell device from the account to reactivate the pro2 Cameras free storage access.
2nd Gen
Arlo Video Doorbell
audio
AVD3001
AVD4001
AVD4001-100AUS
communication
deta
Doorbell
drained battery
Feedback
intermittent
Mechanical chime
no app model
noise
Phonecall
Secure Plus plan
Secure Trial Active
speaker
Talk
wired
Wmb4540
