I understand that some camera the essential kits are good to go to Apple home kit but I have the 2nd gen video doorbell can that go to Apple HomeKit too?
Yessssss!!!!!
Homekit is working now!! I just bought a Video Doorbell 2k and installed it today - paired it with an Arlo Base Hub that I already use for other cameras. As I chose the pair with Base Hub option instead of wifi, it initially connected via wifi to do a firmware update after which the Arlo app asked me to reset the doorbell and reinstall with the Arlo Base Hub option. Once done, I went to Apple Home App and I am able to see the doorbell there 🙂
Interesting. It has not shown up in Apple Home for me yet. Mine is connected through a base station. @JamesC, should the doorbells work with HomeKit now?
The Base Station/SmartHub firmware that includes the update for Home integration is currently in slow rollout. This means it may not be available yet for your system but once your Base Station/SmartHub receives the latest firmware update, you can then add your doorbell to Apple Home. For latest firmware versions, see here: https://community.arlo.com/t5/Firmware-Release-Notes/Arlo-Firmware-Release-Table/m-p/1920885#M791
@JamesC, thanks for the reply. Interestingly, one of my doorbells showed up in the home app today, but the other one hasn’t yet.
The doorbell now shows up in the home app, however the video resolution has been drastically reduced. When you go to the video settings within the Arlo app it says “connecting your base station to homekit limits the video resolution to 1536sq”. Will this be fixed?
Not sure it can be - I think this is an Apple restriction.
Thank you for the update, the video doorbell is now visible under the devices on my Apple HomeKit. This is a major improvement as I am able to carry out much needed additional HomeKit automations.
Regards Raymond
Mine looks like it’s the same resolution.
It’s about dang time. Lol.
Apple Home integration is now available for Arlo 2nd Generation devices. For more information on this release, take a look here: https://community.arlo.com/t5/Announcements/Apple-Home-integration-is-now-available-for-Arlo-Essenti...
2nd Gen
Arlo 2nd Gen
Arlo Video Doorbell
audio
AVD3001
AVD4001
AVD4001-100AUS
communication
deta
Doorbell
drained battery
Feedback
homekit
intermittent
Mechanical chime
no app model
noise
Phonecall
reset
Secure Plus plan
Secure Trial Active
speaker
Talk
token
Video
wired
Wmb4540
